Horizontalna signalizacija i obeležavanje puteva 02 avg 2011 18:24 #1
Kako mrzim te farbe za horizontalnu signalizaciju...kad ce vise poceti da koriste hladnu plastiku
Odg: Bulevar Evrope - construction update 02 avg 2011 18:49 #2
Otis.Driftwood napisao/la:
nikad... PR jkp Puta je otvorene rekla kada se svojevremeno povela diskusija u medijima o toj temi, da oni ne planiraju da prelaze na nove metode farbanja jer im se to ne isplati
Odg: Bulevar Evrope - construction update 02 avg 2011 21:11 #3
Wtf je hladna plastika?? Jel moze neka slika kao primer?
Odg: Bulevar Evrope - construction update 02 avg 2011 21:15 #4
evo sa wikipedie
Thermoplastic
One of the most common types of road marking based on its balance between cost and performance longevity, thermoplastic binder systems are generally based on one of three core chemistries: hydrocarbons, rosin esters or maleic modified rosin esters (MMRE). Thermoplastic coatings are generally homogeneous dry mixes of binder resins, plasticizers, glass beads (or other optics), pigments, and fillers. Their use has increased over paints mainly due to the performance benefits of increased durability, retro-reflectivity, and a lack of VOC solvents.
Thermoplastic markings are applied using specially designed vehicles. The thermoplastic mix is heated in trucks to about 200 °C (400 °F) before being fed to the application apparatus. This is often a screed box or ribbon gun. Immediately after the thermoplastic has been applied, glass beads are laid onto the hot material so that they embed before the plastic hardens. These beads provide initial retro-reflection. As the marking wears during use and the initial beads are lost, the beads mixed with the binder are uncovered, providing long term reflectivity. Most thermoplastic is produced in white and yellow colors, but other colors such as red may also be produced.[citation needed]
Hladna plastika isto ovo samo unapred napravljeni oblici koji se na povrsinu nanose tako sto se naslone i zagreju brenerom da se spoje sa podlogom
Plastics were introduced in the late 1960s and early 1970s.[citation needed] Commonly referred to as tape or cold plastic, this product is heavy-grade material with reflective beads embedded in the plastic. It is commonly used to mark crosswalks, stop bars, and traffic guidances such as turn lanes, HOV lanes, train crossings, pedestrian crossings, taxi lanes, bus lanes, and bike lanes.
Preformed Thermoplastic—Preformed thermoplastic pavement markings are applied using a propane heat torch and are used primarily because of their durability and cost-effective service life. Cut and ready to position onto an asphalt or concrete pavement surface, the most common applications of preformed thermoplastic pavement markings are found at intersections as transverse markings such as stop lines, legends, crosswalks, arrows, bike lane symbols, and accessibility symbols
A evo i malo opisa procedure u slikama kako se to u britaniji radi sa krsh aparatima
www.highwaysmaintenance.com/Witepics.htm
Poslednja izmena: 02 avg 2011 21:25 od mukyz.
Odg: Bulevar Evrope - construction update 02 avg 2011 21:26 #5
Inace i kod nas u gradu od nedavno ima termoplastike...
One reljefne trake sto su postavili umesto lezecih policajaca ispred nove skole na novom naselju
Odg: Bulevar Evrope - construction update 03 avg 2011 06:18 #6
Moj kum je sa mojim ocem hteo da zapocne biznih hladnom plastikom
Inace , postoji i na futoskom putu kod one pumpe pre nego sto se skrece desno za novo naselje.
Tu je oznacena biciklisticka staza ali na jako losem asfaltu.
Evo jedna beogradska firma koja se bavi time
www.model5.rs/Hladna%20plastika.htm
Inace , dosta ulica u beogradu je oznaceno hladnom plastikom.
Odg: Bulevar Evrope - construction update 03 avg 2011 07:57 #7
Jeste, sve veće ulice koje su rekonstruisane u poslednje vreme su označene hladnom plastikom. I one crvene šrafure koje zabranjuju zadržavanje na raskrsnici. Mnogo je bolje od farbe. Ne razumem opravdanje našeg JKP Put!? Ne isplati im se... :whistle:
Odg: Bulevar Evrope - construction update 03 avg 2011 08:15 #8
Verovatno se ne isplati onom koji im diluje farbu, pa se oni malo solidarisali... Kao i one sto za 80000 nisu u stanju da regulisu jednu fontanu - najuriti! Mozemo samo da se nadamo da ce g.preduzeca u nekoj garnituri shvatiti da su tu zbog grada, a ne grad zbog njih :pinch: Inace, ta plastika je zakon :cheers:
Odg: Bulevar Evrope - construction update 03 avg 2011 08:30 #9
evo nasao sam i tu vest od 4. maja 2011
Ređe i noćno farbanje puteva nemoguće
Ređe, kao i noćno farbanje gradskih saobraćajnica, u Novom Sadu trenutno nije moguće.
Dugotrajnije smese kojima bi se obeležavala horizontalna signalizacija, za dužinu novosadskih puteva nisu isplative, tvrde za Radio 021 u gradskom preduzeću "Put", koje je zaduženo za ovaj posao. Takođe, farbanje nije moguće tokom noći, kaže portparolka JKP "Put", Jelena Stojsavljević.
"Ovaj posao se mora raditi tokom dana, budući da su potrebni posebni temparaturni uslovi. Znate i sami da smo do skoro imali temperaturu tla ispod plus pet stepeni, što je veoma bitno za farbanje horizontalne signalizacije. Imali smo i dosta kiše, veoma vlažan vremenski period, očekivali smo lepo vreme i temperature vazduha iznad 10 stepeni", objašnjava portparolka JKP "Put".
Noćni radovi izbegavaju se i iz razloga bezbednosti radnika, a Jelena Stojsavljević objašnjava da se kada je toplije može raditi noću, ali samo na bulevarima, jer se u manjim ulicama Novosađani žale na buku mašina kojima se na asfalt nanosi farba. Ona dodaje da radnici rade tokom vikenda i praznika, a plan je da prolećno farbanje svih važnijih saobraćajnica bude gotovo pre Poljoprivrednog sajma, ali će to zavisiti od vremenskih prilika.
Farbanje se potom nastavlja u manjim ulicama, a različitim tempom trajaće do polovine novembra. Pred početak školske godine, obavezno se rade pešački prelazi u blizini svih novosadskih škola. (D.S.)
Odg: Bulevar Evrope - construction update 03 avg 2011 08:59 #10
Sramota!!! Kakve su ovo izjave?? Ne moze ovo ne moze ono njanja..a sta moze gospodjice Jelena?!
Ne isplati se? A da se navede razlog npr??
Zatim...znaci boze kad je bio sajam...i do polovine novembra planiraju da ofarbaju sve puteve?
Pa covek da pomisli da nam grad ima 3miliona st.!
Zaista smo bedni..mi uvek napadamo druge sto zaostajemo ..delom i jesmo u pravu ,medjutim u novije vreme isti ti,koje mi kao pravdamo ,zloupotrebljavaju to..ovo je tipican primer toga.
Odg: Bulevar Evrope - construction update 03 avg 2011 09:21 #11
Sve objašnjava ovom paradoksalnom rečenicom:
:clapping:
Odg: Bulevar Evrope - construction update 03 avg 2011 09:25 #12
Ma gluposti.
Jeste da je hladna plastika skuplja ali barem se ne farba 2 puta godisnje nego jednom u 2 godine.
A i postavlja se pitanje ima li Novi Sad kvalitetnu podlogu , tj kvalitet asfalta za H.P. ?
Odg: Horizontalna signalizacija i obeležavanje puteva 03 avg 2011 15:50 #13
Mislim da bilo koja asfaltna podloga odgovara odnosno najbolje su glatke i srednje grube, sto mislim da je kod nas slucaj.
Postoji i mogucnost da se oznake ugrade u asfalt, tj da se tamo gde treba da dodje oznaka sastruze asfalt do odredjene dubine i onda se to udubljenje napuni
Odg: Horizontalna signalizacija i obeležavanje puteva 08 sep 2011 14:47 #14
moram da prenesem jednu fantasticu vest...
naime ne znam da li nas neko cita ili sta ali onaj najnoviji deo bulevara evrope koji prolazi ispred kasarne se upravo u ovom momentu obelezava toplom i hladnom plastikom, imaju i neku novu masinu za to... i kruzni tok ce biti obelezen sa time, a isprekidane linije ce biti reljefne, protivupavljujuce :cheers: :cheers: :cheers: :clapping: :banana: :rock:
nema slika posto sam bio u kolima
Odg: Horizontalna signalizacija i obeležavanje puteva 08 sep 2011 14:55 #15
Odlicno :banana:
Ja sam sve vise siguran da nas dosta ljudi cita :yes: Sad kad osvane onaj WC na Porti :whistle:
Poslednja izmena: 08 sep 2011 14:56 od limanac.
Odg: Horizontalna signalizacija i obeležavanje puteva 08 sep 2011 15:16 #16
i da meni isprekidaju ispred zgrade liniju :D buahahahaha, i to sa hladnom plastikom, Zahtevam to koliko sutra :D :D :cheers:
Poslednja izmena: 08 sep 2011 15:16 od Nixivoje.
Odg: Horizontalna signalizacija i obeležavanje puteva 08 sep 2011 17:11 #17
Slikajte sto pre !!!
Odg: Horizontalna signalizacija i obeležavanje puteva 09 sep 2011 12:25 #18
Da slikaj! hahah :) tako treba svugde da urade
Odg: Horizontalna signalizacija i obeležavanje puteva 09 sep 2011 17:27 #19
evo vam smaraci :D
Poslednja izmena: 09 sep 2011 22:50 od mukyz.
Zahvalnici: Nicisy1, Buck, limanac, hfusion
Odg: Horizontalna signalizacija i obeležavanje puteva 09 sep 2011 19:31 #20
Mukyz, care! Ja danas išao za Rumenku, pa sam vozio cik cak da slišam kako prelazim preko linija :)
